Two things.
Except for how it looks, a one horn air cleaner, the van air cleaner is a standard looking air cleaner if you don't want to deal with the box. I could not figure out where to put it, so I found this m-body cop one instead. But could have gone with the van one.
Second, I had thought about the fuel pump from the truck, but two things stopped me. Well 3 really.
One the fuel sending unit isn't compatible, as I recall, so I would have no idea how much gas was in it.
Second, I think the fuel pump unit as a whole is deeper than my fuel tank. You may find that different for you.
Third, the cost of one if you have to replace it was pretty outrageous, but again I was looking at the 98 and up.
Your bonus is you don't have to figure out a return line like I did since it is self regulating at the pump.
