I do not like the cam but would only change one thing at a time High velocity for the heads on a street car you are only 15% bigger than stock and not revving past 6000 I do not think you need MW ports check the width of the stripe of a sharpie on the tip of your valve stem and let's see how your current geometry is time to get it spot on with the change posted at the end of pg one I'll read the rest
