The Wilwoods are 1.38" and the Strange have 1.625 and 1.750" pistons.
There you go. Do the math to figure the difference in piston area x eight pistons. The bigger the piston, the more pressure is applied to the pads.
Put a decent caliper on it, plumb the rears to the MC port closest to the pushrod if the rear tires are larger than the front, throw the prop valve out. Expect to need the MC bore to be bigger with appropriate calipers on there.
If the results don't match the theory, change the theory.
