I thought the wildwood prop valve produce more pressure when turned in. Just the opposite you would think. Try that
It's not a Wilwood valve but I did adjust it and check to make sure it was wide open.
I just got off the phone with Wilwood, they said it's not far off on the rear pressure but the front is low. The tech suggested I start at the mc checking pressures and work my way through the system. I'm going to remove the adjustable proportioning first and check the pressure. If that doesn't improve it I'll fab up lines and go through the system.
Thanks guys, Justin.
