A couple pics of the soffit framing and a stack of siding and soffit that will be the next phase to begin.
All siding and soffit are Mastic Products.
Color for the siding is "Harbor Grey".
Grey J channel will be used on the ends with eaves under the soffit and around the door frames while white soffit trim will be used at the front and rear elevations at the rear of the soffit.
I'm going to make all of the exterior fascia and soffit trim using the .040 aluminum typical to the inside at the garage doors rather than the thin rolled products readily available.
I have some pretty neat materials ordered for the front elevation...no maintenance at all...
I'll post pics once they come in...
Garage door supplier was on site and measured the openings after the trim installation so once they arrive they will be installed also.
