Just did another check of my LH motor mount. This car has power steering so it's not the easiest to see but I set the mercy brake on the car and popped the clutch a few times. Had someone watch the motor mount and even took a video. The rubber does separate and is cracked almost all the way across about 1/16th from the top of the mount. It's not all the way thru though cause the motor still does not raise up enough from left to right under torque for the air cleaner to tag the hood. It does indicate a questionable mount. Car does not shake or anything slip while the brake is set and popping the clutch to raise the motor.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
