Yes I have checked for drive shaft yoke slop as it sets in the tranny. Non there. Compared to my 71 Cuda and it's pretty much the same.
Bell housing has not been dialed in. I wonder though that if that were the cause wouldn't I have other issues going on?
Replaced tranny front bearing.
Checking drive train alignment left to right would be something to pursue. I haven't checked that. U joints are good.
Mopar Performance super stock springs.
Yes gradual clutch engagement will still shake. If you just get it rolling you can boil the tires after that but hang onto your hats if you try this from a standing start.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
