Could clutch disc when released, not move freely on transmission main spline. I had always checked for this many years ago when was still replacing clutches, did so before bolting pressure plate in place. More than once had found a problem,,,,and a couple of times with a disc not runing true when spun on a smooth bench top surface.
I will post this thought on the other thread of the day suggesting another clutch problem.
