Step back a second.
There have been some instances in the 300+ boxes I've sold with unexplained angles.
B/E Ks are interchangeable, however, the bodies are different in terms of the location of the columns, I have found cases where K's were not with their respective bodies.
Then why would a factory box fit fine before the swap? So far I'm 2 for 3 installed having alignment issues. The other one leaked from the weld. All 3 were swaps with their original K Frames and factory boxes. I'm probably going to pull the trigger on #4 before my June track day.
