Combo 1- corrected flywheel hp - 911 (My memory is a little foggy, but i think this car may have actually gone 147mph) Moroso hp for 3660/147 = 890
Combo 2- corrected flywheel hp - 652 Moroso hp for 3470/131 = 610
Combo 3- corrected flywheel hp - 705 Moroso hp for 4200/123 = 600
All built by me, all dynoed by me on the same dyno. IMO, the dyno is a much more reliable way of determining engine output, as you can see from these examples, and my friends stocker, that some cars just make better use of the avalable power than others.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
