Does anyone know if these bolt in Shock tower supports allow for stud type shocks to be mounted near or in the stock location? Just wondering as this would make changing over to coil overs pretty easy without changing very much.
Tory's setup your shocks mount in stock location. He makes a bracket that ties in to your upper control arms if you need it. I have Afco da stud mounted shocks on my car.
Do you have any pics with the upper shock supports mounted? I've got some afco stud mount shocks that I plan on using with the stock control arms. I could go ahead convert to coil overs if one of these supports allows for that style of mounting at the top of the shock. Would be nice to lose the torsion bars and the weight.
