John, what spindles are you using and are you planning on changing those also, I would have to go look at my set-up again but if I remember correct every thing bolted to the spindle flange where the origional brakes were attached.
This car is all stock Mopar up front so stock mopar spindles. My small tire 74 Duster is stock mopar spindles too with an after marker system and rack n pinion steering but we did LOTS of work to get the steering right. My black 70 car is really the nicest with strange struts. VERY easy to work on.
I removed the stock 76 disc spindles and went to a factory 10" drum spindle on mine.
Light travels faster than the speed of sound,,,this is why some people seem bright untill you hear them speak.
