Originally Posted By dartman366
Mike can you get the trans tailshaft extention housing off while in the car? if you can then take it off and disassemble the govenor and clean it, sounds like it's sticking or it's got a piece of trash in it, and you don't want to hear what a trans shop told me how to fix it with out taking it apart,,,it worked but not reccomended. LOL shock
No way in hell to get it off... I spent a hour trying
to get a fitting into the governor port today and found
it couldnt be done.. I ended up pulling the carpet and
drilled a 1" hole in the tunnel so I could get my readings..
I did do the drive to park and drive to reverse thing...
nothing changed(I assume that is what you were gonna say
about the fix)
wave
