Thanks guys!
Problem with Moparts is that few actually read the question fully.
With an ALTERKATION front end, I'd remove the front tires, block up ant LCA to ride height and use a digital protractor to set camber, toe you said you could do, caster, well I wouldn't worry about it as you are planning to have it professionally aligned.
They say there are no such thing as a stupid question.
They say there is always the exception that proves the rule.
Don't be the exception.
