YES !YES! YES! Thank You All for all of your help!!
I finally got to the car this morning . I took off the rockers and put a wire down each side(Stealth heads must only have one hole to oil the heads in the stands. The other one is blind about an inch down) and could feel it drop into the cam while turning the crank . Low and behold when running the drill and slowly turning the crank I got a GUSHER out of each side!!!
