Re: R&D For Both Big/Small block
[Re: MR_P_BODY]
#1664673
08/29/14 02:35 PM
08/29/14 02:35 PM
Maybe by then you will have rebuilt your engine for the 4th time and finally gotten it right, your tranny for the 3rd time and finally gotten it right, cut apart your suspension and finally gotten it right....and maybe even make a pass at the track by 2015...or 16....
And maybe, just maybe, I'll have my car ready to make a pass in 2015...maybe...but I am sure it will be an unimpressive slug...
Your right... I did have some set backs with my ride that I BUILT ... but YOU WOULD NEVER KNOW ABOUT BUILDING anything since all you run is your little street STOCK car... maybe JUST MAYBE you might have changed a carb on and thats ALL.... so when YOU BUILD anything that turns out PERFECT you make sure you get on here and tell us ALL.. oh.. I forget... you dont build ANYTHING
You been stalking me ? How would you know anything ?
As I said, my Car will be an unimpressive slug when i get it out....
Or was this meant for Monte after he writes the check at the chassis shop ? and picks up the free engine from his buddy ?
