Re: R&D For Both Big/Small block
[Re: Street Monkies]
#1664651
08/28/14 11:27 AM
08/28/14 11:27 AM
Posts: 167 maryland
74yellowduster
maryland
http://thitek.net/news/jesses-200mph-challenger-hot-rod-magazine/Quote:
Built by Spankin Time Performance in San Bernardino, California, Jesse Iwuji’s Challenger uses a Darton-sleeved, 408ci Hemi stroker crank from Scat spinning a set of Carillo rods and CP pistons. The engine also has ThiTek heads and a 4.2L Kenne Bell supercharger that runs as much as 22 psi of boost on E85. The exhaust uses OVX long tube headers, Bassani mid-pipes, and Flowmaster Super 40–Series mufflers.
The 912 rwhp gets to the ground by way of an SHR transmission, a DSS driveshaft, and the stock differential and axles with 3.06 gears. With that combo, Jesse became the fifth modern Mopar to break the 200-mph barrier in the standing mile, running 200.9 mph. He’s also run 174 mph in the half-mile, which is the same speed our showroom-stock ’13 Dodge Challenger SRT ran in a mile and a half.
http://www.nmcadigital.com/2013/09/19/br...r-for-rob-goss/
i guess some R&D must be goin on
