http://www.mcmaster.com/#6692k11/=ss05gu
This is what most around here use. Just plumb a line to manifold and connect to back of valve. Mount valve within drivers reach and simply pull slide on this out to create a vacuum leak (lean out).
Hope this helps...
Now that is cool. I think I will have one of them. Never seen one
