I put a vacumn pump on and that cured all the water problems. The pump came off a 1987 camaro. Put a vented catch can and plumb it in. I notice just a little water vaper for the first 2 to 3 minutes then nothing. Rember to turn the pump on before you start the motor, The crank pressure will push oil out the seals and gaskets.
If the MODS did their job I would not be hitting the notify MOD button. LOL
