It takes no time for the E85 to milk down my Brad Penn oil.
It looks like crap. i run evac system and thats all. there is a tremendous amount of moisture in the motor.
Talking to a few guys at the track who run E85, they are talking about "lean out valves" and running the motor 200 degrees and such. Does not sound good to me.
Is E85 really this difficult? Small Block stroker 418,W-2, roller, drag race set up.
Sounds rich but the lean out valves work... I never
had any milking in the oil once your in the range..
even without the lean out valve.. but the lean out
valve will save you fuel during the warm up
