What did the motor dyno? I have a Ray Barton built 528 in my 71 Cuda. The car is very heavy 3950 lbs. I've run a best time of 9.88 @ 141 mph. If I work on the 60 ft times I should be able to run 9.50's or 60's. Not all of Ray's 528's are built the same. Mine is a Mopar performance mega block and a pump gas motor with only 10.4 compression. High compression could give me almost another 100 hp. You are going to be at a disadvantage with a stick shift and high gears but you still should be able to get into the 10's if you can hook it up.
How much did yours dnyo at and what is your combo if you don't mind me asking?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
