Do you have a roll bar in the car? It is most likely closer to 3700 lbs with you in the car. You are most likely going to start out in the low 11's until you start to get it sorted out. But you should be able to get the car in the high 10's depending on how well you shift. The stick shift with 3.54 gears will hold you back. Where did you motor make peak horsepower?
No roll bar in the car and the motor made peak horsepower at 6400 and peak torque at 5200.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
