The OP's car is clearly a street toy and is not prepped for real race duty. Bolting on some sticky tires and adding cal tracs aren't gonna be enough to hook that thing.
As stated, with those power numbers, you should have no problem running well below the 11.49 cut off, which will lead to you being booted from the track for no rollbar, no harnesses etc.
A 700 HP hemi in a good drag car, will run well into the 9's @ 140mph+
Maybe in a light A Body but in a heavy (3700) E body 700 hp only gets you into the low 10's
