I would try 30 and 32 degrees total timing and see if that helps the MPH, all the SB with iron heads that I have helped tuned like it I have absolutely no experience with the heads your running so if you have treid 30 and 32 and your motors likes 35 please let us know, I'm sure there are more than one other SB Mopar on here are using them
