Quote: The Milidon pan is a no go! But on a better note I unbolted the pan without loosening motor mounts or anything else for that matter and the 971 pan slid out like butter. Now I plan on putting the stock 971 pan back in and a accusump as mentioned earlier. The stock 971 is a P5007807AB I just need A 1/2" pickup P5249818. Ill have to cut the existing pick up off to remove it. I think the stock one will spin right on. The accusump was an excellent suggestion as was the 66-69 pan.. Thanks
huh ???
The 971 pan is a 4 qt sump pan for a 73-74 B body and there is no 1/2" pickup made for that pan.
This pan, P5007807AB , is a deep sump pan ... according to the google search I just did ... just like the one your wife smashed .
