You've got the chance to make it a streetable car now. Sadly, if you built that engine correctly with a pickup hanging down to the bottom of the pan the engine will need to come out to swap the pick up tube for a shallower unit.
How many people do you know that would build a motor and install the wrong pickup?
Good people make honest mistakes all the time.
Lots of gearheads get all wound up about the hard parts of the engine and miss the stuff that doesn't move around.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
