Re: 4 Speed Breakage
[Re: 68KillerBee]
#1473196
07/24/13 06:24 PM
07/24/13 06:24 PM
Posts: 15,498 Omaha Ne
TJP
Omaha Ne
Lot's of answers found in the old thread. You actually helped out also. Here is the one I could find. Seems this issue has been going on longer than I remembered.
https://board.moparts.org/ubbthreads/showflat.php?Number=5264280
From one of your posts in the old thread Quote:
with the clutch, pressure plate, d-shaft and trans out there was no vibration at any rpm. put in new clutch, pressure plate, flywheel (refurbished from brewers), rebuilt transmission, new throw out bearing, and the vibration is still there
Re read that several times and think it through, the answer appears to be somewhere in the second sentence of the above quote
