Re: 4 Speed Breakage
[Re: finn]
#1473176
07/24/13 11:30 AM
07/24/13 11:30 AM
Posts: 4,462 Morristown Tn.
71birdJ68
Morristown Tn.
After sleeping on this, I bet that bellhousing needed to be indexed even though it was stock, and was just a bit too far off
This , new bellhousing , it is not indexed to the engine . Original bellhousing are attached to the engine block when it is being machined and mated to it .
I can see that you have never been in an engine machining / assembly plant.
The only thing attached to an engine block for machining is the bearing caps or main bearing bedplate (if equipped).
A bellhousing is machined separately, most likely in a separate plant, or at a minimum in a separate area of the plant, and taken off a palate or feeder and randomly selected to be bolted to the back of an engine. This is a relatively non-critical joint as far as geometry goes.
Looks like an assembly error to me. Probably left the bolts loose.
Accidents happen, especially on long term off again / on again projects.
Did that hold true for the 1900s, before cnc's,computers,ect.? Why would the book say if the housings were swapped from different blocks that they need indexed. And if its not critical why are we only allowed .004 runout?
