Cast crank or forged , internal or external balance ? Was the flywheel checked for neutral if it's a neutral as i see it is an OLD original flywheel. SS springs , was the pinion angle corrected when they were originally installed as they do change the pinion angle.
Yes indexing is the offset dowel deal. Do you have a picture of that bellhousing when it was in one piece ?
Link to old thread on this issue ?
Lot's of answers found in the old thread. You actually helped out also.
Here is the one I could find. Seems this issue has been going on longer than I remembered.
https://board.moparts.org/ubbthreads/showflat.php?Number=5264280
