Hmmm... I forgot about the cam snout issue. I'm going to be pulling the front cover on my 340 soon to advance the cam a little bit. Front covers on all LA engines are the same, correct? No funky stuff just for the 360, right? I can take a measurement of the cam or the cover, whatever you need. I've also got a solid 318 sitting on a dolly in the garage if you need the info SOON...
