Thats some good info myduster...you do bring up an issue. I put my battery in the trunk and the turbo now takes up that space in the engine bay. Hope the PS pump on the Magnum setup doesn't come too close since I cant notch the turbo. I have 98 Durango 5.9, so I will make some measurements before jumping in. Thanks for the help! Anyone else?
70 Coronet- turbocharged 360/518/3.73 SG
