Quote: The floor hump has nuttin to do w/the rod placement. If anything, the shifter plate might cure it, but I doubt it. You most likely have the incorrect rods. My
Yeah, I agree. However, the plate could have ramifications to the hump placement, but in this case I think it will be okay doing a side-by-side on the plates.
