Quote: On the rockers a lot of the ductile iron rockers won't be the advertised ratio, usually less when checked at the retainers I would, if you can afford it, buy the good Harland Sharp full roller aluminum rocker arms, not the cheaper extruded aluminum non roller shaft ones they now offer
