Also... being its a street car and a stick, build torque forget about the HP... build all the torque you can.. a bigger ci engine normally makes torque at a lower rpm so you dont have to spin it hard and if you have the torque you have plenty of gear for the street... the stick helps also since you can take off at any rpm you wish
