Some Tags do not have the correct info on them from the factory, does that make those Tags FAKE?
By your own admission you're 'new' to mopars so just where did you pull that BS from? The cars are built to the tag and sheet, not the other way around.
EK3 is an odd example since he has the buildsheet, window sticker AND a picture of THE ORIGINAL tag. So a 'correct' copy may be possible. ASSuming the font, size and spacing can be duplicated of course.
If you bought a car without a tag, or somehow lost it, tough, suck it up and mark it down as a lesson learned. Just make sure the next mopar you spend money on has a bit better documentation.
A fake tag, window sticker or sheet is the kiss of death to anyone that knows these cars and only useful when trying to sell a car to someone that DOESN'T know much about them.
I can't afford this.
mark
