The mechanical six pack Holley 2300 carbs were sold over the counter under the Direct Connection banner as "Racing" carbs. They were also used on Ford's during the '60's. It takes a bit of searching, but there are still a lot of nice sets out there, especially if you Google Ford set-ups.
Those carbs were 500 cc 2 bbl's with accelerator pumps. That is all I ran on 6pk setup in the late 70's and early 80's.
How do you make the Ford carbs fit a Mopar manifold?
the mechanical end carbs were the same size throttle bores and venturi as the factory vacuums, definitely not the 500cfm aftermarket carbs. the ford carbs will bolt up but they were very small, like the mopar and chevy center carbs.
Actually since the Ford carbs all have metering blocks the rear carb won't fit... The center carb always has a metering block so that's not an issue & the front carb just protrudes an extra 3/4" but the rear carb will not fit....
"The Armies of our ancestors were lucky, in that they were not trailed by a second army of pencil pushers."
