So, just thinking during my lunch break today. Main priorities for the brake system for Friday and Saturday...
1) Bench Bleed and replace the Master Cylinder. 2) If time and skills permit... Replace wheel cylinders... 3) If more time and skills permit... Replace lines.
Good/Bad? Do you think I will be fine with just replacing the Master Cylinder instead of making this too complicated or burdensome than it should be?
