Quote: O, so that's when Harbor Freight came into the mix. I kind of just glazed through the last couple posts. I just have standard line wrenches (3 contact points) not the flare nut wrenches. ....
He're getting caught up in terminology.
Some people call those Flare Nut Wrenches, Line Wrenches. I think because you use them on Hydraulic/Air lines.
You need set of those to do brake work.
The bleeder screws can be loosened with a 6-point socket of the correct size. DO NOT use a 12-point socket on those.
It would take you 5 minutes to spray the bleeder screws with penetrate. You don't need to jack up the car again.
If you only have one day of limited time to fix your brakes next weekend, just replace what is bad (master cly.) and bleed the brakes.
