Quote: Well I picked up a new ECU at the local auto parts store and it seems so far to do the trick!
Success . I didn't think the 4 terminal ballast harness was used in '69. I'm assuming the 4 terminal ballast will plug in to the harness (has 2 double ends) only 1 way so that you are on the lowest ohm half of the ballast. As you researched the other side of the ballast is not used on a 4 pin ECU.
