From the ECU to the coil is wired correctly. The only wire that is in the harness to the ECU but not being used is (green with a red tracer) still running to the ballast not sure why or where it goes from there must be wrapped up in the wiring harness somewhere?
I can try running a ground wire from the mounting screw on the ECU directly to the battery.
