.if it was me i would buy a new one and install,should be able to grab one for 25.00 at autozone or the likes
this would be my suggestion.
X3. Less likely would be the coil or the pickup (check the gap though). Unrelated to your issue you mentioned a 4 terminal ballast, clarify that if you would
