I got the cowl Epoxy primed with PPG DP90LF black. i will put 3 coats of PPG K36 filler primer on it, then wet sand it with 320 and then 500 after it is guide coated, then reseal it again with DP90LF. i will be ready to shoot color soon on the cowl and under the hood area.
