Did the trans work correctly prior to the recent TF-2 installation and was it using the exact same TP linkage? Does the TP linkage have a spring pulling it forward against the throttle lever stud?
Try temporarily disconnecting the TP linkage at the trans lever and pull the lever full forward, if it upshifts earlier than normal with the linkage disconnected the linkage is the problem.
The INTERNET, the MISinformation superhighway
