I would not trim fuel at first. It's prolly lean now. Unless the plug shows otherwise, just pull some timing. I'd pull four degrees and sneek back up on it.
It's an air distribution problem. You have a pic of the intake plumbed up?
"These go to eleven", Nigel Tufnel
