Do you have a pic of the brake pads for those jumbo jet size calipers?.
They are Brembo calipers.
There are 4 brake pads per caliper. Two pistons push on each pad. The leading pistons are 28 mm and the trailing pistons are 32 mm. The total caliper volume is not as large as you might think. That allows you to run a moderate size master cylinder.
In this pic they're shown beside the "big" Mopar 11.75" brakes.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
