I didn't try to look for a weight savings on my brakes. The front rotors alone are 27 lbs each.
When I picked this stuff up 7 years ago there were no big brake kits for old Mopars so I built my own.
They do fill out an 18" wheel nicely.
The stopping power is impressive. There is no fade unless you ride the brakes for a mile or two. The stops are smooth and short. After driving with modern brakes on an old car you won't ever want to go back.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
