Ok, I dropped by the body shop yesterday to give the painter some needed bolts and such. As the car sits now, we are very close to color on the body. The entire underside of the car has been sprayed with restoricks grey dip primer paint and overspray has been fogged onto it. Inner quarters have the sound deadener sprayed on, seam sealer on the trunk floor and everything is sprayed inside the trunk and bottom of the trunklid with base/clear A4 silver. Same goes for the inner doors, door jambs, engine bay and underside of the hood. Looking great so far. Im told I should have the car back by Early October. Getting exciting now.
