I see Hughes makes a 246/252 thats ground on a 106, with about the correct lift with a 1.6 rocker. With that tight of LSA it should sound choppy.
I have that same cam in my 360 with the 1.6 rockers my car is street- strip and i really like it so far.
have you ever had it down the track??
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, low 10.30’s 1/4 1.41 best 60 foot 6.56 at 104.17
