Portage,michigan
Don,
Brian recently built a 360, stock crank/rods/KB107's, 2.02 RHS, Comp XE275HL hyd cam, Air Gap, 750 DP, headers.
Made right at 430hp and 440tq
Not a crazy build and capable of 11.60-11.80's in a well set up car, that I know you are more than capable of putting together.
There are a bunch of different flavors of these heads floating around out there. Make sure you pay attention to the parts that they come with, there is a big difference.
Thanks, good advice.
Actually am kinda leaning toward a 360, it will make a little more torque than a 340, and me being as big as i am and the car being full weight, it might ultimately 60 foot better with a 360 than a 340, and i kind find a block easier. Guessing it will need to make about 460 or 470 with a 904 to get me where i want to get.
Probably like a tti header, weiand excellerator( i love that intake.. and the 318 that was in the demon when i bought it has one already sitting on the motor), proform 750, maybe a hughes flat tappet somewhere about 246/252 ish at 50, that will have a decent little thump, a ptc 9.5 convertor, 4.10 gear and leafs and 8 inch wheels and 10 inch tires.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, low 10.30’s 1/4 1.41 best 60 foot 6.56 at 104.17
