Re: Almost died today, 3 times
[Re: GasHog72]
#1002397
05/30/11 12:23 AM
05/30/11 12:23 AM
Posts: 4,258 State of Fascism
52savoy
State of Fascism
The factory throttle cable is available from different sources... An E-body uses the same cable. http://cgi.ebay.com/ebaymotors/NEW-71-74...=item3a6645764dFrom what I see the kick-down plate(slotted) is touching the wrong end of the carb stud. It should be on the back-end that way when you give it gas it starts to put pressure on the tranny throttle valve right away. so even with the correct stud the tranny kick-down won't work right. need to adjust rod out or replace it with a longer one. I probably have it but seeing you need it now...
Entire Thread
GasHog72
05/30/11 12:45 AM
FuryUs
05/30/11 01:06 AM
GasHog72
05/30/11 01:11 AM
FuryUs
05/30/11 01:15 AM
GasHog72
06/16/11 08:59 PM
Golden-Arm
05/30/11 01:16 AM
GasHog72
05/30/11 01:25 AM
jbc426
05/30/11 01:44 AM
RapidRobert
05/30/11 02:38 AM
GasHog72
05/30/11 03:00 AM
Golden-Arm
05/30/11 03:16 AM
GasHog72
05/30/11 03:32 AM
stinger
05/30/11 03:33 AM
GasHog72
05/30/11 03:45 AM
PC-CHARGER
05/30/11 03:56 AM
GasHog72
05/30/11 03:51 AM
stinger
05/30/11 04:18 AM
GasHog72
05/30/11 04:57 AM
Golden-Arm
05/30/11 01:10 AM
52savoy
05/30/11 04:23 AM
52savoy
05/30/11 04:38 AM
GasHog72
05/30/11 05:00 AM
GasHog72
05/30/11 05:18 AM
stinger
05/30/11 05:29 AM
GasHog72
05/30/11 05:33 AM
GasHog72
05/30/11 06:06 AM
feets
05/30/11 03:50 PM
GasHog72
06/13/11 03:14 AM
GasHog72
06/13/11 03:16 AM
pishta
06/13/11 03:35 AM
GasHog72
06/13/11 03:42 AM
StealthWedge67
06/13/11 05:57 AM
70Cuda383
06/13/11 11:14 AM
GasHog72
06/13/11 06:08 PM
GasHog72
06/13/11 06:25 PM
scratchnfotraction
06/13/11 06:30 PM
GasHog72
06/13/11 06:32 PM
GasHog72
06/13/11 06:59 PM
GasHog72
06/13/11 07:02 PM
GasHog72
06/14/11 02:06 AM
GasHog72
06/14/11 03:46 AM
70Cuda383
06/14/11 02:20 PM
GasHog72
06/16/11 08:45 PM
Golden-Arm
05/30/11 05:24 AM
GasHog72
05/30/11 05:31 AM
